Today I replaced the started and it started fine the first time.
I turned it off after a couple of minutes and tried starting it again a few mins later just to be sure and it didnt start, all I could hear was a single CLICK sound. So Im thinking its not the starter alone thats the issue but what else could it be?
Please help!
Replaced Starter still having problems starting
- DCJREDLINE
- Posts like an LN3
- Year and Trim: None
Re: Replaced Starter still having problems starting
Battery connection?
2004 Saturn Ion 3 Quad Coupe
MKMike
- Posts like an L67
- Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Battery drained from cranking
Bad battery
Bad alternator that's not charging battery enough
Poor connections at the battery
Corrosion on the battery cables
Defective replacement starter.
I would make sure the battery is fully charged and the connections are clean and tight before doing anything else.
Bad battery
