1990 Buick Regal Coupe L67 swap.
Jokebana
- LE Member
- Year and Trim: 1990 Buick Regal Limited Coupe
Hi there, just need to know what's needed for an L27 to an L67 swap. I have the capital I just need a list of things needed for this project. Any help is much appreciated.
Merrillspontiac
- Posts like an LN3
- Year and Trim: 2000 Pontiac Bonneville SE
Re: 1990 Buick Regal Coupe L67 swap.
This sounds very interesting as I would like to do this to a 92 Regal Coupe.
1993 Buick Regal GS Coupe
Jokebana
- LE Member
Yeah I got this Buick in an estate sale she only has 32,000 original miles and the paint is perfect not a dent or rust on this thing. That's why I want to make her my project
- MattStrike
- Year and Trim: '99 Montana
As far as a parts list goes, you would at least want a W-body donor. Having never done the W-body swap, I can't specifically say, but in theory the whole thing should drop out of the donor and into yours.
-Engine
-Harness
-Trans
-Axles
Then there are the main things that slow a swap down, where you'll either have to make adapters or find new parts to make everything work, but sometimes they bolt right in.
-motor mounts
-wire harness adapter (best bet is to have both CSM's and knowledge of basic DC circuits and be handy with solder).
-A/C
-Power steering lines
-heater hoses
-throttle cable
-cruise control
-intake and filter
-exhaust downpipe
A lot of it is tinkering with motor mounts and brackets trying to piece together something that fits. I think you having a L27 car is going to help out because you should have all the brackets and things like that that will fit already. The hardest part is the wiring. You have to adapt the new harness to fit the car. I always make a pass-though adapter with parts from junkyard cars, leaving the main harnesses unmolested, in case anything goes wrong I know where to look.
-Engine
-Harness
-Trans
-Axles
-motor mounts
-A/C
-heater hoses
-throttle cable
-cruise control
-intake and filter
-exhaust downpipe
Jokebana
- LE Member
Well alright that makes sense and the fuel pump going to work or with I have to get an after market one?
Merrillspontiac
- Posts like an LN3
https://www.youtube.com/watch?v=n6LMkjwsQ4s This guy used a series 1.
- MattStrike
Your fuel pump will work fine as long as it's not worn out and you don't plan to do any mods. But I would recommend pulling the fuel pump from the donor as well, though you might have to use the donor sending unit too if the fuel pump is a completely different size.
