3800 non super charged block for a SSEi block swap?
brochazumc
- SE Member
- Year and Trim: 2002 SSEi
I have a 2000 Buick LeSabre with a working 3800 non supercharger. I have a 2003 Bonneville SSEi with a blown #4 cylinder. Will the block of the LeSabre 3800 swap over to the Bonneville? I know EGR and intake must be changed but it seems (or at least I hope) the block would swap over. What about the CAM?
Bonnie Lover Since 99'
- nos4blood70
- Year and Trim: 2003 SLE
Re: 3800 non super charged block for a SSEi block swap?
What you're looking at is what's known as a top swap. Lots of good reading on that here:
http://www.grandprixforums.net/threads/ ... -3800-Info
- Wes
- Posts like a Northstar
- Year and Trim: 2002 Buick Park Ave
Short answer is it will work, but it's not plug and play. I definitely recommend reading through the link Carl posted.
yourgrandma wrote:High
troehr
- LE Member
- Year and Trim: 2001 SLE
The link to grandprixforums no longers works, but you can stilll access the information using the archive.org WayBack machine
https://web.archive.org/web/20150422024 ... -3800-Info
- luke_dubs
- GXP Member
- Year and Trim: 2013 Regal GS
You replied to a post from 2016, just so you know.troehr wrote:The link to grandprixforums no longers works, but you can stilll access the information using the archive.org WayBack machine
'13 Buick Regal GS 122k miles, 270 hp, 295 lb/ft, ZZP intake.
