1989 Oldsmobile Delta 88 Frnt Wheel Bearing Re n Re
89OldsRocket
Year and Trim: 1989 Oldsmobile 88 Royale Brougham Regency - FE3
Post by 89OldsRocket »
Bearings on one side of front are making a grinding noise and getting louder. When turning left they are quiet, straight and turning right they are noisy. Is there a how to on changing these and do I need to buy the hub that has the bearings pre installed/lubed or can I just replace the bearings?
1989 Oldsmobile 88 Royale Brougham Regency - Grey on Grey - FE3 - X06 Package - Limo Tint - Clarion HU - 2K Pontiac Grand Am 15" Alloy Rims
96 SSEi
Re: 1989 Oldsmobile Delta 88 Frnt Wheel Bearing Re n Re
Post by 96 SSEi »
hi, it should be a bearing/hub assembly - much easier than pressing the bearing
similar to this...........https://www.youtube.com/watch?v=DjkVZLxpCPk
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
Look on Rockauto for the parts.
Don't forget to check the Vendor's Forum here for the RA discount code.
ratmonster
Year and Trim: 1989 Bonneville LE
1993 Roadmaster Ltd
Post by ratmonster »
Were you able to get this repair knocked out yet?
89OldsRocket
Was driver side bearing, youtube vid helped, thanks!
