95 Bonnie air conditioning troubleshooting
Posted: Sat Jun 11, 2016 1:46 pm
by DonnieBonnie
That's shows freon okay,. but very little cool air. Any hints on what to start troubleshooting ?
Re: 95 Bonnie air conditioning troubleshooting
Posted: Sat Jun 11, 2016 5:29 pm
by RJolly87
How do you know the freon is okay, and is it blowing plenty of air, just not cold, or is it cold air, but just not a lot of it?
Posted: Sat Jun 11, 2016 6:59 pm
by DonnieBonnie
I added refrigerant to the appropriate pressure reading, but not getting cool air
Posted: Sat Jun 11, 2016 7:16 pm
by RJolly87
Is the compressor running at all? If so, is it staying steadily engaged or cycling? Was it running when you started adding refrigerant?
Posted: Sun Jun 12, 2016 3:22 am
by bobc997615
I don't know if this fits your issue but my 92 SSE had a lot of "air" leaking from the AC ductwork seams before the dash vents. Sealing those or fixing the deteriorated foam seals increased the airflow out of the vents.
Posted: Wed Jul 06, 2016 3:42 pm
by PavliCZek
DonnieBonnie wrote:That's shows freon okay,. but very little cool air. Any hints on what to start troubleshooting ?
Try this ,
viewtopic.php?f=45&t=2432 , i was same problem.
I clean this with hipressure air and vacuum cleaner , look this after one year ,
Posted: Thu Jul 07, 2016 11:53 pm
by redfury
When you say you checked pressure, did you use a gauge set, or a gauge on a can of refrigerant? Knowing the high side and low side readings will help identify the problem. A properly running system will keep the compressor engaged most of the time on MAX cool, but when you change to regular A/C , it will cycle. Fast cycling ( on/off/on ) within a few seconds usually indicates a low charge.
Other things that can affect cold output are moisture in the system ( how did you charge this back up? Was it completely empty? ) Also, heat transfer. Is the evaporator and condenser clean of debris? Run cold water on the condenser and see if the temps go down significantly. If you have a bad orifice tube, that can cause problems as well. A weak compressor or a blend door that isn't keeping hot coolant from mixing with it can also cause problems.
Good luck and report back what you discover.
Posted: Mon Jul 11, 2016 9:03 pm
by Jrs3800
Also just to note R134a is a fickle beast... If its a tad low it wont function properly, if its a tad over charged it won't function properly.. Its not as forgiving as R12..
Is the compressor and its related parts all original?
