95 Bonnie air conditioning troubleshooting
DonnieBonnie
- LE Member
- Year and Trim: 1995 SSE
That's shows freon okay,. but very little cool air. Any hints on what to start troubleshooting ?
- RJolly87
Re: 95 Bonnie air conditioning troubleshooting
How do you know the freon is okay, and is it blowing plenty of air, just not cold, or is it cold air, but just not a lot of it?
DonnieBonnie
- LE Member
I added refrigerant to the appropriate pressure reading, but not getting cool air
- RJolly87
Is the compressor running at all? If so, is it staying steadily engaged or cycling? Was it running when you started adding refrigerant?
bobc997615
- Year and Trim: 1992 SSE
2005 GXP
I don't know if this fits your issue but my 92 SSE had a lot of "air" leaking from the AC ductwork seams before the dash vents. Sealing those or fixing the deteriorated foam seals increased the airflow out of the vents.
- PavliCZek
- LE Member
- Year and Trim: 2x 1992 SEEi Green & White
Try this , viewtopic.php?f=45&t=2432 , i was same problem.DonnieBonnie wrote:That's shows freon okay,. but very little cool air. Any hints on what to start troubleshooting ?
I clean this with hipressure air and vacuum cleaner , look this after one year ,
Garage:
1992 Bonneville SSEi Green Metalic
1992 Bonneville SSEi White
1995 Mercedes Benz W140 S420 Coupé
1999 Cadillac Seville STS
1999 Dodge Grand Caravan ES 4WD
2007 Volkswagen Phaeton W12 6.0
1994 Lincoln Mark VIII sold , now only sweet memory
http://www.fuelly.com/driver/bazyg
SpaceSim Game Star Citizen if you want to play Star Citizen when registering, use my SC code which will add 5000aUEC game currency.
https://robertsspaceindustries.com/enli ... -V9XR-LJ3F
- redfury
- Posts like an LN3
- Year and Trim: 2000 SLE Saved from the scrapyard.
When you say you checked pressure, did you use a gauge set, or a gauge on a can of refrigerant? Knowing the high side and low side readings will help identify the problem. A properly running system will keep the compressor engaged most of the time on MAX cool, but when you change to regular A/C , it will cycle. Fast cycling ( on/off/on ) within a few seconds usually indicates a low charge.
Other things that can affect cold output are moisture in the system ( how did you charge this back up? Was it completely empty? ) Also, heat transfer. Is the evaporator and condenser clean of debris? Run cold water on the condenser and see if the temps go down significantly. If you have a bad orifice tube, that can cause problems as well. A weak compressor or a blend door that isn't keeping hot coolant from mixing with it can also cause problems.
Good luck and report back what you discover.
Also just to note R134a is a fickle beast... If its a tad low it wont function properly, if its a tad over charged it won't function properly.. Its not as forgiving as R12..
Is the compressor and its related parts all original?
