Slowly with time and lots of TLC brought her back into fine shape and she has treated me very well since Dec 2005....
Recently however a head-scratcher of an annoying, if not concerning problem of bucking has shown up: Only when under load such as climbing even mild road grades, or passing gear auto downshifts but with this one caveat: It's ONLY in 4th gear above 50mph. When locking out OD by manually downshifting into 3rd gear and remaining there for remainder of highway trips, the bucking is non existent even past 70+mph. Present once again when back in OD-4th.
I'm theorizing a number of possible problem origins from a throttle position sensor to faulty trans shift sensors, valves or
OD clutch failing...Okay now boys; rack your Pontiac history encrusted brains for similar occurrences will ya now?
Gimme some solid intel here...
I don't just want to throw part$ at it, of course, but no useful DTC codes other than a small evap leak someplace.
Any true blue knowledgeable transmission guys out there on line?
If a trans rebuild is in my future, my budget dictates I would have to pick up a used 4T60-E with low as possible miles someplace - any "buyer bewares" with that scenario?
