Oil pressure drops
omargadea12
- SE Member
- Year and Trim: 95 Pontiac SSEI Supercharged 3.8L
Oil pressure drops
Hello everyone, just yesterday at a stop light my oil pressure gauge drop to the red line. When i press on the gas it comes back up on a delay and the engine icon comes on. Any thoughts, thanks.
- Jfridge92
- Posts like an L67
- Year and Trim: 1999 Buick Lesabre Custom
Re: Oil pressure drops
can you verify that the pressure is actually dropping with a mechanical pressure gauge? Or was there an audible knock or ticking from the engine when pressure dropped? A lot of times, the oil pressure sending unit can fail and cause inaccurate readings, so it's always best to verify with a mechanical gauge.
Joseph
1999 Infiniti G20T - Sold
RandyVaughan
- LE Member
- Year and Trim: 1994 Pontiac Bonneville
it is possible that your oil sending sensor is going out.ive incounterd the same thing.
SATADrive420
- Year and Trim: 1998 Bonneville SE
It's most likely the sending unit.You should look into getting it replaced soon before it starts to leak oil.
1998 Pontiac Bonneville SE with XM Radio, Heated Seats and more! (Retired)
2009 Chevrolet Impala LTZ (Daily Driver)
96 SSEi
- Posts like a Northstar
hi, my 96 oil pressure would be low on idle and increase with rpm but it never hit the red!!!!
If it was my ride, I would make this my first priority - check oil viscosity and level also - do you have access to another 3800 to switch the senders?
also, are you noticing an increase of top end chatter? you can pull the oil filler cap and see if oil is making its way up to the valve/rocker assembly
RandyVaughan
- LE Member
I replaced my oil sending sensor and made the mistake of trying to start it when the car was still jacked up and now a code flashes inflatable situation. now I must get it hooked up to a computer and have the codes cleard before it will start. don't be an idiot like me haha.i have oil pressure now.
RandyVaughan
- LE Member
is there anyone who knows how to clear codes on a 94 Pontiac Bonneville 3.8 liter or does this have to be done by computer?
96 SSEi
you live and learn man.......where do you live? maybe a member with scanner lives near you.....you can rent it from parts store also..............hang in there!!!!
ok, just saw your new post.........................look here.....http://www.pontiacbonnevilleclub.com/fo ... 27759.html
00beast near the bottom.....happy trails
maxi426
- SSE Member
- Year and Trim: 2003 SSEi
1999 Park Ave. Ultra L67
If you have codes, simply clearing them will not allow the car to start. There is something else going on. Is it possible that you got the wrong sender that's not sending power to the fuel pump? Check that your new sender has the same number of pins as the old one.
