Struts
override93
Year and Trim: 2001 Pontiac Bonneville ssei
Struts
Post by override93 »
Can I use quick struts from a park ave and use them on my 01 bonneville ssei? I know they have different part numbers but is it something to 've worked around?
djdani3l10
Year and Trim: 2005 Pontiac Bonneville SE
Re: Struts
Post by djdani3l10 »
i believe you can, its just the spring height on them is different, and therefore the bonneville will sit higher.
i was going to purchase the quick strut from a park avenue but found out that it would lift my car slightly in the front and just ended up getting ones made for the bonneville.
but then again you can play around and switch the springs if you have time haha.
override93
Re: Struts
Thanks. Ya don't have time.. who know s that extra height might help in winter haha
Re: Struts
Put your SSEi springs on the PA struts and you'll be fine.
