CMNTMXR57 wrote:Did I miss something about your G8 mang? I mean, I knew (purposely spelled correctly BTW), that you had that body work done awhile back... But I'm gonna say 9 times outta 10, anything put together by Holden is > than anything put together by GMNA of that vintage.
Well, let's see, by 62,000 miles:
3 sets of lower control arms
Incessant alignment issues
Idler pulley
Airbag clock spring
Steering rack
Shrinking hardening leather on the seats
Steering wheel replaced twice for the same shrinking
Lifters
Lots of undercarriage surface rust
Bubbling/peeling paint on the trailing edge of the rear wheel wells
Rusting axleback flanges
Airbag module
Trans bracket whine
Driveshaft harmonics
Incurable water leaks
Driver seat back making an internal unsticking noise when I move
Transmission flare
Faded wiper arms that also have deteriorated washer fluid spray patterns
Failed wheel stud
Coolant temp sensor
Radio/HVAC occasionally looses its *shoot*
Even knowing it's fragile before ever using, flasher button is basically inoperable after using it a handful of times despite my gentle pushes
I am likely forgetting several things
The Grand Am that accumulated miles at 3 times the rate:
Rear struts
Water pump
Radio knob
Turn signals with random actuation
1 wheel bearing
I might be forgetting a few things.
