F-Body brakes on 00+
Posted: Mon Nov 09, 2015 6:46 pm
by 98SSE
I'm in need of some new front brakes and have a set of JY f-body brakes (Core obviously) in the garage. I was reading around on here the other day but didn't find anything definitive as to what is needed to exactly install these. On my 99' GTP I had to have the brackets tapped for the GP bolt and this is where my confusion is. Do I need to tap the bracket for the Bonneville bolt or is it the same thread and will bolt right up? Just wanted to clarify before I go diving in. If I have to order some banjo bolts and shims that's not a big deal to me. Thanks!
Post I was skimming through.
http://www.pontiacbonnevilleclub.com/fo ... 36870.html
http://www.pontiacbonnevilleclub.com/fo ... 39623.html
http://www.pontiacbonnevilleclub.com/fo ... =12&t=2447
http://www.pontiacbonnevilleclub.com/fo ... c3308.html
Re: F-Body brakes on 00+
Posted: Mon Nov 09, 2015 7:17 pm
by MattStrike
95NAsta has the writeup in his how-to for dropping the '92-'99 cars. You can either drill and tap or use a bushing in the hole to take up the gap.
Posted: Mon Nov 09, 2015 7:20 pm
by 98SSE
Good deal, thanks man. I guess I just assumed it was for the previous gens.
http://95nasta.infiniteboost.com/wp-con ... e_1pt1.pdf
For anyone who might be searching in the future. Page 9.
Posted: Wed Jul 27, 2016 6:47 pm
by 02230bbc
I have a 2002 SSEI and I want to do a F Body brake upgrade can the stock Bonny brake lines be used?
Posted: Thu Jul 28, 2016 7:23 pm
by 98SSE
02230bbc wrote:I have a 2002 SSEI and I want to do a F Body brake upgrade can the stock Bonny brake lines be used?
Yes, I just bent/adjusted mine accordingly. Been about 10k+ miles so far.
