F-Body brakes on 00+
98SSE
Year and Trim: 2001 SSEI/2007 TBSS/2004 CTS-V
Post by 98SSE »
I'm in need of some new front brakes and have a set of JY f-body brakes (Core obviously) in the garage. I was reading around on here the other day but didn't find anything definitive as to what is needed to exactly install these. On my 99' GTP I had to have the brackets tapped for the GP bolt and this is where my confusion is. Do I need to tap the bracket for the Bonneville bolt or is it the same thread and will bolt right up? Just wanted to clarify before I go diving in. If I have to order some banjo bolts and shims that's not a big deal to me. Thanks!
Post I was skimming through.
http://www.pontiacbonnevilleclub.com/fo ... 36870.html
http://www.pontiacbonnevilleclub.com/fo ... 39623.html
http://www.pontiacbonnevilleclub.com/fo ... =12&t=2447
http://www.pontiacbonnevilleclub.com/fo ... c3308.html
"Big 3", Tint
MattStrike
Year and Trim: '99 Montana
'92 Trofeo
Re: F-Body brakes on 00+
Post by MattStrike »
95NAsta has the writeup in his how-to for dropping the '92-'99 cars. You can either drill and tap or use a bushing in the hole to take up the gap.
98SSE
Post by 98SSE »
Good deal, thanks man. I guess I just assumed it was for the previous gens.
http://95nasta.infiniteboost.com/wp-con ... e_1pt1.pdf
For anyone who might be searching in the future. Page 9.
"Big 3", Tint
02230bbc
Year and Trim: 2002 ssei
Post by 02230bbc »
I have a 2002 SSEI and I want to do a F Body brake upgrade can the stock Bonny brake lines be used?
98SSE
Post by 98SSE »
02230bbc wrote:I have a 2002 SSEI and I want to do a F Body brake upgrade can the stock Bonny brake lines be used?
Yes, I just bent/adjusted mine accordingly. Been about 10k+ miles so far.
"Big 3", Tint
