Drivers Info Center not responding,just scrolls non stop
STAGE III
Year and Trim: Black 2000 SSEI
Post by STAGE III »
Okay been looking around for o er an hour so decided to just ask.
Our 2000 SSEI D.I.C. lights up but just scrolls through warnings non stop. Does not respond to oil reset as none of the buttons respond. Pushed buttons from every angle and pressure, nothing :dontknow:
I can try a hard reset but doubt that will fix it. As the worst case scenario does anyone have a link or experience replacing the whole unit? I have dealt with the bad wheel sensor lights (ABS,traction control, etc) but the Info Center advertizing how screwed up it is has crossed the line [-X
Anyone have a spare or suggestions?
Thanks for any help :beerchug:
John
North Carolina:
2000 SSEI (FINALLY something nice! Thank you Lord!)
1970 Buick GS 455 STOCK 510ft lbs of torque at 2800rpm's! (in works)
1972 Buick GS Stage 1 (total basket case)
1960 Buick Electra 225 convertible (when "225" stood for 225" long)
1976 & 77 Jeep (Just Empty Every Pocket!) Wagoneer 360 AMC
ddalder
Re: Drivers Info Center not responding,just scrolls non stop
Post by ddalder »
Have you actually scanned the car to see if there are any codes? What warnings exactly is it displaying? Try disconnecting the control switches to see what happens.
