New Owner with a problem
bigchieftaco90
- Year and Trim: 2001 SSEi
Hey guys! I just bought my 2001 Bonneville SSEi yesterday and I noticed no air comes out of any of the vents.
I tried to change the mode, a/c, heat, passenger side, etc and nothing seems to work.
I read something about the blend doors being behind the glove box but I don't know what I'm looking at back there.
What do you guys think? I took the cabin filter out and ordered a new one because it was super dirty.
bigchieftaco90
Re: New Owner with a problem
http://www.amazon.com/ACDelco-15-72645- ... B0016IIXVI
Will that fix it? How difficult is it to replace?
Current Rides:.................................Previous Rides:
**2001 Bonneville SSEi.......................**2005 Nissan 350z
**2005 Grand Cherokee 5.7 Hemi..........**1997 Grand Cherokee 4.slow
**2011 Chevy Malibu..........................**1995 Olds 88 RIP
**2005 Honda VTX1300.......................**2008 Suzuki GSX-R600
bigchieftaco90
Also, I forgot to mention. I looked in the fuse panel under the hood and I noticed I am missing relay #33 HVAC SOL. Does anyone else not have this relay? I stole a relay from the high beams and it didn't change anything.
- brownishSLE
- SE Member
- Year and Trim: 2000 SLE
bigchieftaco90 wrote:relay #33 HVAC SOL.
Don't quote me on this, but judging from pg. 6-65 in the manual: http://www.pontiac.com/content/dam/pont ... manual.pdf you tried to swap in a relay (one for a high beam, number 28 or 27) for a solenoid. I know they do slightly different things: http://science.blurtit.com/82011/what-i ... a-solenoid , so you would have to swap in an identical solenoid to be sure it's the original solenoid's fault.bigchieftaco90 wrote:I stole a relay from the high beams and it didn't change anything.
brownishSLE
"Family heirloom" Brown-on-brown 2000 SLE
It's not winter anymore.
I'll get a new photo up
soon.
soon.
bigchieftaco90
Hmm, that shows #33 as being different sizes than the high/low beam relays. Mine are all the same size.brownishSLE wrote:bigchieftaco90 wrote:relay #33 HVAC SOL.Don't quote me on this, but judging from pg. 6-65 in the manual: http://www.pontiac.com/content/dam/pont ... manual.pdf you tried to swap in a relay (one for a high beam, number 28 or 27) for a solenoid. I know they do slightly different things: http://science.blurtit.com/82011/what-i ... a-solenoid , so you would have to swap in an identical solenoid to be sure it's the original solenoid's fault.bigchieftaco90 wrote:I stole a relay from the high beams and it didn't change anything.
- brownishSLE
- SE Member
Ok. Sorry I'm stumped. The manual is usually the extent of my knowledge.bigchieftaco90 wrote:Mine are all the same size.
brownishSLE
soon.
soon.
- Archon
Is the blower motor turning on?
bigchieftaco90
Yeah, the motor works fine. I can hear it running and changing speeds. It's like all the vent doors are closed shut and won't open.Archon wrote:Is the blower motor turning on?
- Archon
That's the confusing part. I'm not aware of any position of the various doors that will prevent air from moving. The air mix actuators changes the temperature, and the mode changes where the air is directed. The air inlet actuator changes from outside air, to recirculating. None of these should stop the air flow.
I'll have to check my car for relay 33. Was the one you swapped in, from the high beams the same part number?
bigchieftaco90
Yeah, it's quite confusing. I drove it to work this morning and it was cold. It does warm up in the cabin but not like it should. I'd like to get this fixed so I can use the defrost when I'll need it.Archon wrote:That's the confusing part. I'm not aware of any position of the various doors that will prevent air from moving. The air mix actuators changes the temperature, and the mode changes where the air is directed. The air inlet actuator changes from outside air, to recirculating. None of these should stop the air flow.
I'm not sure about the part numbers being the same. I just noticed it shared the same slot style as the high beam lol. I'll do a bit of digging.
Edit: Well, looks like that is not the issue.
http://www.pontiacbonnevilleclub.com/fo ... 66&start=0
Oldman
- Posts like an LN3
There's an additional fuse box under the back seat. Fuses 2, 11 and 33 are all associated with the blower and HVAC system also. Might want to check those, I'm not sure exactly what those fuses do.
bigchieftaco90
Well I checked those a bit ago and they are all fine.
Any other ideas? Think its the mode actuator?
A couple people in this thread have a similar issue. Mine is always blocked though. http://www.pontiacbonnevilleclub.com/fo ... 40013.html
- Archon
Unfortunately, no one reported back on what was found to be the problem. Searching through things, I have been unable to find anything that would totally stop the air flow. There are a few things that you could try.
With the cabin air filter out, observe the fan when it is running. Check to see if the squirrel cage is spinning to be sure that it hasn't somehow come loose from the motor shaft.
Remove the blower, and stick you hand in the vent area to see if you can feel anything that may be in the way. You'll only be able to get a little ways.
Observe the various actuators to see if they are moving when they should.
bigchieftaco90
Thanks for the info. I wish they would of chimed back in to tell us what happened.Archon wrote:Unfortunately, no one reported back on what was found to be the problem. Searching through things, I have been unable to find anything that would totally stop the air flow. There are a few things that you could try.
I'll take a look at the motor tonight and see if anything happens when its running. My new filter comes in tonight.
I'm wondering if a mouse made a nest in the vents or something. I've had that happen in the squirrel cage before but that was so smelly it was unbearable(maybe I had a dead one huh)
I hope its something simple. I just haven't had a ton of time to check it out.
How easy is it to remove the blower? I've read it can be a PITA
Thanks for pointing me in the right direction.
Edit: Found this article. http://www.pontiacbonnevilleclub.com/fo ... 41571.html
I will be having the radio out one of these days so while I'm in there I'll check the wire harness to the HVAC controls.
bigchieftaco90
I checked the HVAC controls connection and everything looked fine. Visually inspected the squirrel cage and it looked fine.
The next step would be remove the blower motor and see if anything is clogging the vents.
I did notice the rear vents blow air and my feet get pretty warm. So it's getting through the center console fine. Any ideas guys? I'm pretty sure its the mode actuator.
- Archon
So, you really are getting air movement? These don't seem to have a lot of air movement to the floor. If you have air, and it's just not changing where is is directed, then yes, that is likely the mode actuator.
Oldman
- Posts like an LN3
Yeah I've had a mode actuator get stuck between "floor" and "face" setting and when the airflow was split, it was difficult to tell that any air was coming out at all.
