Harmonic Balancer?
irish91983
1992 Bonneville SSEi (Sold)
Harmonic Balancer?
Post by irish91983 »
Hi All
I was wondering what other members have used to remove the harmonic balancer? I know GM call for a special tool, but can you use any puller for it? part numbers or pictures of tool use would be big help.
Thanks, Keith
2001 SSEi Bumbles
Archon
Re: Harmonic Balancer?
Post by Archon »
There is really only one good way to remove it, and that is with a harmonic balancer puller. This is a good post on it from techinfo.
http://www.pontiacbonnevilleclub.com/fo ... c8267.html
buickman104
Year and Trim: N/A
Post by buickman104 »
I bought this and it worked like a charm!
http://www.amazon.com/gp/product/B000P0 ... ge_o05_s00
everything fit well and no issues.
You use a standard puller, but they don't come with the right size/pitch bolts in the "kit". Also, some struggle with the bolt into the crank not coming loose, but the thread on removal has a nice guide on that if you don't have access to air tools.
irish91983
thanks for the info. I have one more question are the L67 and L36 the same balancer? I checked rock auto they have different part numbers listed.
Thanks keith.
2001 SSEi Bumbles
robauto
Year and Trim: 2003 SE
Post by robauto »
I used a standard balancer puller but you need M6 x 1.0 bolts, 70-90 mm long (2.75-3.5 in) I used about 75mm. for the crank bolt use an impact gun. I had to go forward first, then reverse. ensure the air pressure is at its highest and use a good powerful gun and a high quality 6 pt socket.
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
irish91983 wrote:thanks for the info. I have one more question are the L67 and L36 the same balancer? I checked rock auto they have different part numbers listed.
Thanks keith.
They are different; the L67 HB has 2 sets of grooves for 2 belts.
The L36 only uses a single belt.
