P Code 1676
ShaneC
- Year and Trim: 98 Bonneville SE 3800 S2
P Code 1676
So, i just got the 98 se (Midnight Magic-MM) back from the shop on friday. original engine went bad and i was able to pick up a used one with only 136k on it from a local AAA yard. MM has run for just under 180 miles since i got him back friday morning. on the way home from work today my check engine light came on
, so, when i got home home i pluged in the code reader and got said P Code (1676)
looking online i was able to find that it has somthing to do with the EVAP and a selondoind of some kind. all of that is way over my head lol
i was wondering if anyone on here had first hand knowledge with this problem and a SIMPLE step by step to get it fixed? if not at least some lead on where i could look to get an idea of it. i would be very greatful for any help in this matter. Thanks
They call me...Snowflake
Mine:1998 Pontiac Bonneville SE 3800 II 250k miles (Bad engine)
MODS: all chrome lug nuts, ported UIM LIM, 180 T-stat
In Progress: Finished overhaul under the hood, & updated interior.
OURS(DD): 2003 Pontiac Grand Prix 3100SFI 165k miles MODS: custom lights both front and back
Hers: 04 Pontiac Aztec Base model. More to come later
MKMike
- Posts like an L67
- Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Re: P Code 1676
EVAP CANISTER PURGE SOLENOID VALVE CONTROL is on the engine near the coils and has 2 vacuum lines going to it.
Make sure the vacuum lines aren't disconnected or cracked. Check that the wires , the electrical connector and all the pins it plugs onto are in good condition.
If these things are OK, then replace it.
You can get a replacement for around $30
ShaneC
Re: P Code 1676
