Repaint
- nos4blood70
- Year and Trim: 2003 SLE
Re: Repaint
Depends on the quality of the job, but you should be prepared to spend in thousands of dollars range if you want it to be decent.
1oldman
Re: Repaint
If you're thinking about a GM Diamond Tri-Coat paint ot the white pearl, that's some serious money just for the paint. - BCTmajevo wrote:How much to get 2002 bonneville se painted pearl white? Or black?
Re: Repaint
I've looked into getting my car repainted as thoroughly as possible. Just as they said before, its going to be at least $2,000, and that's probably just a basic job. If you want a pearl white with the GM diamond tri-coat like he said, thousands and then some. Plus having to find the exact color. Are you repainting because your clear coat failed and its oxidized or you just want another color?
Re: Repaint
More than the car is worth...
96 SSEi
- Posts like a Northstar
Re: Repaint
hi, you could do it yourself if you rent a shop for 50+/hour lets say 5 hours for beginners -250
white is cheapest colour( I would guess 200 for paint and 100 for clear in paint-- you can practice with a spray can then you'll be good and it will be decent.The same technique basically but now you use professional equipment.
500-700 probably total for diy
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
Re: Repaint
For a paint job that will look at least half way ok you should expect at least $4,000 - $5,000.
- Sirius
- Year and Trim: 2003 SSEi
Re: Repaint
Take it to a body shop near you and get an estimate. All you can get here is a W.A.G. as there are far too many variables to consider. It costs considerably more to change the color of your car than to repaint the same color, for instance. Pearls, candies, and other special paints will add cost in material and require different techniques to apply them properly (think more labor cost). How much body work is required before actually spraying the color? $ca-ching$ If you're thinking less than $1000 to paint your car, that's not reality. I sprayed arctic white on the fiberglass tonneau cover for my pickup and I was into that job $300 in material alone. And I did it in my backyard with my own spray gun. And I'm a hack.
If you're just looking for a W.A.G., I think a decent paint job will start at about $3000 and go up from there.
Resident Tightwadgweg_b wrote:People think I'm nuts, but Matt proved it.
Screw you, Photobucket.
desertpierat
Re: Repaint
x2, and I write estimates for a living.00Beast wrote:More than the car is worth...
2000 Pontiac Bonneville SSEi
2010 GMC Acadia SLT2 (wife's car)
ShaneC
- Year and Trim: 98 Bonneville SE 3800 S2
Re: Repaint
It all depends on where you live and what shops you have around you. my home town has only 900 some people in it and the car detailer we have charges based on car type and what all you want done i.e. custom job or just a repaint/whole new color. He averages out at round 1200 bucks. The bigger cities an hour to two away on the other hand normally start out at at least 2000 bucks for just a plain repaint. So I totally agree on taking it in to a few different shops and getting a price range.
They call me...Snowflake
Mine:1998 Pontiac Bonneville SE 3800 II 250k miles (Bad engine)
MODS: all chrome lug nuts, ported UIM LIM, 180 T-stat
In Progress: Finished overhaul under the hood, & updated interior.
OURS(DD): 2003 Pontiac Grand Prix 3100SFI 165k miles MODS: custom lights both front and back
Hers: 04 Pontiac Aztec Base model. More to come later
