2003 SLE
Re: 2003 SLE
I had an 04 Olds Alero with that same issue. Happened after I got the car back from the body shop following an accident. I took it to a dealership to get looked at and they told me it was something to do with (now don't quote me on this) a "antilock sensor(s) that was going bad". Something to do with the brakes.
Now, on my SE Bonnie, my brake light & antilock lights would come on. I had to pull over and reset it by turning off and on the car. Last week I replaced my brakes(they were really bad) and now those lights have not come on ever since.
Good luck!
Good luck!
2005 Pontiac Bonneville SE
- Archon
Re: 2003 SLE
The most common cause is a bad wheel speed sensor in the hub. However, there are other causes, too. The only way to know is to have it scanned with a scanner that can read abs codes.
Re: 2003 SLE
Yes what they said (previous comment)! I couldn't remember the name of the sensor, but that's what I had issues with, with my Alero.
Re: 2003 SLE
Does the Brake light come on when this happens as well? Also does this happen as soon as you start the car or after you start moving?
- J Wikoff
- Year and Trim: 1992 SSE
Re: 2003 SLE
You might consider changing the title of the thread so it draws attention to your issue.
mikeluscher159
- SSE Member
- Year and Trim: 2002 Bonneville SLE
Re: 2003 SLE
Do you have any way to scan the car?
- nos4blood70
- Year and Trim: 2003 SLE
Re: 2003 SLE
TechII scanner could tell you what's up. In my case, it was the EBCM.
