battery dieing issues, need help
Berryhill.tattooist
- LE Member
- Year and Trim: 2000 ssei 3.1-hotcam-42.5#-intercooled-cai
I have a 2000 Bonneville ssei that ive had for a few months now. The battery seemed to die pretty easily so i bought a brand new one from autozone. One day about a week ago i got an unknown driver message on the dic. When i turned th e key the dash lights would come on but wouldbt crank over or click or do anything. The power windows and seats wouldnt work and the key fob wouldn't work. I jumped the car with cables and it fired right up. I let the car run for about a half hour and ran it around the block. Ran just fine and everything seemed fine. I parked the car in the drive way and shut it off, immediately tried to fire it back up and again it was dead and the unknown driver message was gone. I jumped it again and unhooked the battery while it was running to see if the alternator was bad, but it ran fine with the battery unhooked. I brought the battery back to have it tested and they said it was fine but almost completely dead. They charged it and i brought it back home and re installed it. The car fired right up and everything again seemed tpbe fine for about three days. Now today it seems to be dead again because its doing the same *dang* thing, wont start but.no messages on the dic. Ive searced the forums but cant seem to find a similar problem. Some posts claim to search for certain modules or bad connections, i dont know where to start. The car has hid's and an aftermarket radio. But there has been a lot of mods done to it too. Just looking for help and advice, thanks
Berryhill.tattooist
- LE Member
Re: battery dieing issues, need help
theres a switch by the radio for the hids but they guy i got it from said to just leave it up, and when you turn the car off just to make sure the lights are off. which i always do. and the aftermarket stereo is a tv dvd head unit that would make it super hard to check the connections there. Something has to be draining to battery...just dont know what
- haro1225
- Posts like a Northstar
- Year and Trim: 2004 GTO
Sounds like something is not wired correctly, and killing the battery. Check all the grounds and all of the wiring for the radio. Also never unhook the battery while the car is running, it could damage the pcm, among other things.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
- RJolly87
Also have the charging system tested. 3 days sounds about right for a good battery and dead alternator. Also check and clean for corrosion.
rustyroger
- Posts like an LG3
- Year and Trim: 1998 Buick Park Avenue
Try disconnecting the ground terminal to the battery and putting a bulb in sequence though the terminal and lead. If it lights up something is draining the battery.
If so check if any lights are on, especially the trunk light, if you are doing this alone or can't get in the trunk take the bulb out and see if this makes a difference. Then remove the fuses in turn and see if any of them stop the drain. Remember things like the clock and ecu memory use a tiny amount of current all the time, but a good battery should be fine for several weeks before it can't start the engine.
It's conceivable the battery won't hold a charge, simply leave the battery disconnected after charging it and see if it's still ok after a couple of days.
Roger.
Roger.
