Dome Lights not working!
OnlyAnSE
Year and Trim: 2001 Bonneville SE
Post by OnlyAnSE »
My interior dome lights went out a couple of days ago so I figured fuse right? Well today I found the fuse that was broken amd replaced it. Everything was fine, until tonight when I was driving home and when I parked and pulled the key out there was no light again! What is causing these fuses to blow so rapidly? Any help is appreciated thanks!
Morgan
04 gxp bone stock internals. Touchscreen dash with heavily upgraded sounds system.
1oldman
Re: Dome Lights not working!
Post by 1oldman »
Check to see if the correct size fuse is installed. If it is the correct size, then something is drawing more power than it should. You'll have to get an electrical schematic to know all the items on that circuit, then unplug them one by one. - BC
Jnegrea93
Year and Trim: "00 ssei"
Post by Jnegrea93 »
There could also be a broken wire touching another part of the car
