Odd problem after fwi install!
Rubidon
- Year and Trim: 2000 SSEI
Today after I installed my Intense FWI i have no music per say. The radio comes on and my after market amp turns on for the subs and i get base ,but it is like my stock bose amp doesn't turn on. Another odd thing i noticed is that the compass is stuck on SE. Everything was fine this morning on my way home from work, it all started after i put the fwi in. Could in possible have something to do with me moving the pcm around? I took it out of the stock box and into the intense tray.
GXP front break upgrade, hockey puck front mount, aeroforce gauge in right top vent, Intense FWI
- spoiledred94
- Posts like a Northstar
- Year and Trim: Black 2001 Bonneville SSEi
Re: Odd problem after fwi install!
Id say yeah. There's ton of wires and connections for the pcm/. check them out and reseat the connectors. I used some dialectric grease on the connectors too. I don't know if it helped but I'm pretty sure it did.Rubidon wrote:///Could in possible have something to do with me moving the pcm around? I took it out of the stock box and into the intense tray...
ttyl
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
- bobgto65
- Posts like an L36
- Year and Trim: 2002 SSEi
2004 Bonneville GXP - Location: Maryland
Check you amp and compass fuses in the rear fuse block as well.
bobgto65
- nos4blood70
- Year and Trim: 2003 SLE
I'm not sure the FWI would cause that. Check out the wiring in the trunk and the fuse box under the back seat.
Rubidon
I have narrowed it down to the GMOS 09 adapter. I am getting a remote turn on signal to the adaptor but not out of it . If I jump the adaptor the i get music!! Woohoo!!
