Quick Torque Specs Question
Ramcharger310
Year and Trim: 01 Bonneville SSEi
Post by Ramcharger310 »
Changing the motor mount right now. What is the torque specs (ft-lbs) for the 3 bolts that mount the bracket to the engine and how much for the nut(s) on the trans mount itself?
Thanks
David
Edit*
Car is 01 SSEi
Found some specs, still not sure if correct.
Engine Mount Bolts_____________________Ft/Lbs
Vin 3 and Vin C:
Engine mount bolts.....................70
Torque converter bolts.................46
Lower trans to engine bolts............55
Starter mounting bolts.................35
mrrcom
Re: Quick Torque Specs Question
Post by mrrcom »
I know your car is a year newer but i figured id at least try. lol
My GM manual for my '00 SSEI says the torque for the bracket bolts is 75 ft/lb, the nut attaching the bracket to the mount is 59 ft/lb, and the the 2 nuts attaching the mount to the frame are 52 ft/lb. The top nut is 35 ft/lb.
The other book with the transaxle info is at home. I can get that info when I get home
