Hard starting only sometimes
I own a 2000 Pontiac Bonneville ssei but it has a small issue that's bugging me. Sometimes the car will start with one key turn and there is other times i have to hold the key in start position and tap the gas to start it. I tested the battery, starter, and alternator and they all tested good.
Hj2392
- Year and Trim: 99 Bonneville SSEI
98 Bonneville SE - Location: Racine,WI
Re: Hard starting only sometimes
Check for fuel leak or if you have the tools check your fuel oressure. My 99 was having occasional hard starts until I replaced a section of fuel line that had a pin hole leak.
99 SSEI gutted air box, K&N panel filter, Kenwood H.U.
98 SE Mechman 250 amp alt, XS power d3700, 2 runs 0 gauge, Kenwood H.U., 24 cubic foot box tuned for ~34 HZ, 2x 18" Audioque HDC3, GTP chrome 5 spoke, blizzak studable winter treads
I found the problem. I cleaned all the carbon off the iac valve and the car starts every time now and no more weird idle
- nos4blood70
- Year and Trim: 2003 SLE
At least it was an easy fix. If you have the time, the whole throttle body could probably use a cleaning as well.
