Hi All,
I can't remember and need to get the correct size hex bit for someone else... I seem to recall that the pins that hold the caliper to the spindle were 10mm allen heads. Is that correct?
Size of the front brake caliper bolts on a 90 Bonneville?
- clm2112
- Retired Gearhead
- Year and Trim: 1990 Bonneville LE
Djkthegame
- GXP Member
1987 Bonneville LE - Location: Lockport, IL
Re: Size of the front brake caliper bolts on a 90 Bonneville
A 3/8 drive t-50 torx bit socket
"CERTIFIED BONNIEHOLIC"
B I-1999 Bonneville SE -My First Bonnie- gone forever
B II-2000 Bonneville SSEi (black) 7/3/09 ZZpcm 1.0, Thrasher Cold Air Intake, Magnaflow hi-flow cat, 180 thermostat, Autolite 104's, solid hockey puck front mount, Intense 3.4 MPS. (OCT 2010 COTM Nominee)
B III-1987 Bonneville LE (burgundy) 7/22/10 -- Gone to Heaven
B IV-1991 Bonneville LE (black) 12/6/12 Parts Car -- Gone!
B V-1998 Bonneville SE (green) 9/11/13 -- 270,000+ and going strong! -- gone 287k+
B VI-1989 Bonneville SSE(gray)9/23/15
rustyroger
- Posts like an LG3
- Year and Trim: 1998 Buick Park Avenue
A t50 torx is the correct size, unless you have good quality tools I recommend using a 1/2" drive, those bolts are pretty *dang* tight!.
When you put them back be sure to use threadlocker.
Roger.
Roger.
