fuse panel
97BonneSSEi40th
Year and Trim: 1997 40th SSEI
fuse panel
Post by 97BonneSSEi40th »
Why are the fuses not where the manual says they are suppose to be. Every one seems to be mixed up.
KM AXer
Year and Trim: 1993 SSE Medium Garnet Red Metallic, Gray
Re: fuse panel
Post by KM AXer »
Hmmm.
The panel cover usually has a map for size/use inside, so you can see what circuit each one protects. I am having an issue with the ABS/TC pump, so I had to pull the main fuse for that system. The cover was tough to get off, located at the top of the firewall in the engine compartment. Is that the fuse panel you are referring to?
Alan Sheidler
Proud Third Caretaker of the Family Heirloom '93 SSE
Medium Garnet Red Metallic, Gray Leather Interior
Silver Cross-Lace Wheels (I love this car)
95naSTA
Re: fuse panel
Post by 95naSTA »
The manual will tell you where they should be. Why they aren't there is a question for the previous owner or mechanic.
spoiledred94
Re: fuse panel
Post by spoiledred94 »
Yeah I think KM Axer has a good point. There are 3 main fuse locations on the mid 90's Bonnies. Under the drivers dash, under the passenger dash and along the very top of the firewall on the inside of the eng bay. Plus there are numerous inline fuses. I noticed the same thing I think you're talking about: the fuse panel diagram on the lid shows a 10 amp fuse in such and such location for example but thats not what's there. The FSMs are very helpful for this. If you're going to work on your car I definitely recommend getting a set. Even within a model year there are changes in design and the fuse diagrams don't alwaysgetupdated.
great car. Wrecked
Burnt Bonny.
