1997 sse sway bar bushing size?
erickaltman
Year and Trim: 1997 Pontiac Bonneville SSe
Post by erickaltman »
i have a 1997 bonneville sse and im trying to replace the sway bar bushings but when i go to the auto store they say they have 28,30,32,34mm etc? can anyone tell me what one is on the 1997 or how to figure out what size i need, Thanks in advance
J Wikoff
Re: 1997 sse sway bar bushing size?
Post by J Wikoff »
Front, correct? The exact size may not matter a whole lot. Assuming you've got the FE2 suspension, you'd want a 30 or 32 mm bushing. I've got a 32 on one side and a 30 on the other. At first look, they seem like they won't fit, but the bracket squishes the bushing into shape and I can see no discernable difference in the fit. But you may have to measure yours to actually know what you have.
erickaltman
Just measured mine today at work and its a 32mm
Post by Jrs3800 »
All SSEi's from 92-99 use a 32mm front and 22mm rear.. Get the ploy bushings if you can..
