Universal Catalytic Converter Install
jmusser218
- Year and Trim: 2001 Pontiac Bonneville SE
I just received my new catalytic converter from Magnaflow and it is a universal. From taking a quick look at the one on the car, there seems to be very little pipe between the mounting bracket attached to the downpipe and the converter body. Is there enough to cut the pipe and clamp on the new converter? I don't have access to welding equipment or else I would weld the bracket onto the converter. Has anyone had troubles with installing universals? How have you guys gone about this?
- harofreak00
Re: Universal Catalytic Converter Install
If you didn't get a converter with the flange on it, you will definitely need to have it welded.
- ChibiBlackSheep
- Year and Trim: 2000 Monte Carlo SS
It's never recommended to put a clamp on the cat because of how hot that area gets.
CSC Powered 2000 Monte Carlo SS - Project Car
2013 Camaro 1LS - Daily Driver
1968 Camaro SS - Show Car
Abbby
- SSE Member
- Year and Trim: 2003 SLE 208,000 miles
2003 SLE 196,000 miles
Where is the best deal on one with the flanges that will bolt right up?
- harofreak00
jmusser218
I didn't have money for the direct fit. But I found a guy locally that will do it the right way and weld it on for me (for cheap). Thanks everyone for the input!
