New and need HELP
New and need HELP
- BonnieBoy08
- Posts like an L27
- Year and Trim: 2003 SSEi
Re: New and need HELP
Head gasket replacement is not necessary, failure of those is almost unheard of in the 3800 engines. The bolts shouldn't need replacing. Not a bad idea to do valve cover gaskets, plugs, wires, while you have easy access to everything when its all apart. Metal coolant elbows are also a good thing to do at this point. I went thru this a few months back and here are a few helpful hints from a thread I started. YouTube also has some good videos demonstrating this repair. Hope this helps, good luck on the repair.
http://www.pontiacbonnevilleclub.com/fo ... 39581.html Mine has a supercharger so things will vary slightly but this will give you the jist. If you use the search tool you will be able to find other threads with info. Let us know if you have any further questions. Oh yea...and welcome to the forum!
-Nick
- J Wikoff
- Year and Trim: 1992 SSE
Yeah, I'd only do the headgaskets if you have signs of failure. Problems with them are rare enough that replacing them as preventative maintenence isn't needed.
Thanks for the info. I don't want to fix what isn't broken. What are the signs of head gasket failure?
- J Wikoff
They are pretty similar to a LIM gasket or upper manifold failure, overheating from lack of coolant, burning coolant, and coolant in the oil, which is what leads to a lot of the confusion. But additionally, there could be exhaust bubbling in the coolant reservoir and loss of compression.
- nos4blood70
- Year and Trim: 2003 SLE
Welcome!
For what it's worth, 3800s basically never have head gasket failures.
- toastedoats
- Retired Gearhead
- Year and Trim: 1986_Monte_SS_60k
2002_Maxima_SE_160k - Location: Fitchburg.MA
Welsome!
What I would do:
Swap to Dorman upper intake
Replace lower intake gaskets
Swap to metal coolant elbows
there is basically zero chance you need to do the head gaskets
What I would do:
-Aaron-
1986 Monte Carlo SS- The Toy
2002 Nissan Maxima - The Daily Beater
2010 VW CC - The Wife's
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
Welcome aboard. I'd say the same as previously mentioned. Head Gasket failure is highly unlikely the case with these motors. I bought an SSEi from a guy that said the head gaskets were blown and he went as far as getting the top end gasket kits and everything needed but just parked the car. I picked it up, the problem was a $14 water pump and the LIM gaskets.
Re: New and need HELP (Thanks)
Thanks a lot for all your help. I took apart upper intake and found that the PVC tube was broken off. The gasket and the EGR port was fine but will replace anyway. Both lower intake gaskets were blown through in many spots. I will be putting everything back together today Feb 17. I'll post results later.
Re: New and need HELP/ Thanks for all the help
I replaced UIG and LIG. All good to go now.
- gonzo4191
- Year and Trim: 91 S10 P/U
97 SSEI- 136k - Location: round lake beach, IL
Great to hear
