Car idles then shuts off a few seconds later
walle4577
Year and Trim: 2000 Bonneville SE
Post by walle4577 »
My 2000 Bonneville starts and runs for a few seconds, then idles rough and dies out soon after. I restart it and it does the same thing until I hold in the gas for a while and keep the rpm's up around 2000. What could be causing this?
J Wikoff
Re: Car idles then shuts off a few seconds later
Post by J Wikoff »
Vacuum leak, gummed TB, weak IAC, all come to mind.
94SilverSSEi
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
Post by 94SilverSSEi »
Do you have any warning lights? Check engine?
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
02Bonney
Post by 02Bonney »
Cat?
I would give the throttle body and all the sensors a good cleaning.
walle4577
Post by walle4577 »
Yes, the check engine light is on. I had the codes checked, and the only thing that came up was the air flow sensor, my air filter was dirty, I replaced it though.
mrwildroot
Post by mrwildroot »
Quick test:
Unplug the MAF sensor, then try starting/running the engine...
If it runs properly, clean or replace MAF sensor. Don't use Bosch tho, OEM, new or used.
Contact 'Harofreak00' for a good used one.
