painted grille gone bad
ptrfair
Year and Trim: 2007 Impala SS
1997 LeSabre Limited
Post by ptrfair »
okay so im trying to avoid buying a new grille for the SE.
A year ago sprayed my grille with rustoleum chrome paint. With NO Primer. :angry7: therefore it chipped on me. So i then took paint thinner to the grille and the most of the paint came off.
I bought duplicolor primer, chrome and then clear coat. Its been doing great til the other day i noticed the paint chipping off.
What do i do . .
Do i buy a new grille?
Try to clean it off with paint thinner and just buy krylon silver hammered for plastics?
if i repaint my current grille or buy a new one and paint, do i just krylon and thats it? no primer?
Does anyone know of a billet grille or any other aftermarket grille i can get my hands on?
save me from myself...
2007 Impala SS - 30k 5.3L V8
1997 LeSabre Limited - 115k
Gone but never forgotten:
2001 Bonneville SE
1992 Bonneville SE
SingsCountry1967
Location: North of Buffalo, NY __Been there, done that, got the t-shirts
Re: painted grille gone bad
Post by SingsCountry1967 »
I used Krylon Fusion- specifically for plastic applications for automotives...this was June of 2006... I do not have a paint chip to this very day and I drive 18k miles per year (so...I've gone 32,000 miles with this paint.) I don't think that the bodystyle makes a diff (mine is 2000)...
I'm not sure what to tell you about getting the paint off...but if you ever do get it back to bare plastic... go with the Krylon... no primer necessary.
'00 SLE Maple Red -"Crisis Management" - (125k)- Customized in Silver... Driven with Excitement. RIP 2013 the Crisis is Over
Plugs/wires @ 51k, UIM/LIM gasket @ 59k. Ignition Ctrl Modual @ 109k '04 Monte Carlo SS - "Dream Chaser" - 3.8L SII - (82k miles)...Purchased 8-7-08...Still Driving!
Grimm
Post by Grimm »
I agree, get something for plastic. I did mine over a year ago with Duplicolor (not for plastic) and it was going great until I saw it the first time I washed it after the winter and it's chipping off.
chopper442
Year and Trim: 1997 SSE
Post by chopper442 »
I agree....you have to use something formulated to bond to plastic, the Krylon is the best. The grill area takes alot of abuse with bugs and crap...cracks paint - wash - instant flake. Be careful with some liquid strippers(if you go that route)..some are not plastic friendly and will warp parts....
1997 SSE - Bright White -Gutted box, Overlays, GTA vents, cleared corners, calipers..so far.
mas
Year and Trim: 1998 Boneville SE
1991 LeSabre Limited
Post by mas »
the only thing I can think of is that spray balm paint is about half as hard as what the factory or auto body shop uses, they use 2-pack paint. the problem is it contains Isocyanates which over time build up in the blood stream causing death. at minimum an air fed visor should be worn when spraying this stuff and a VERY well ventilated area (for example roof mounted exhaust units). u need an auto body license to buy this stuff here in canada any ways or a friend that works for a body shop :) all the chemically goodness makes this a hard paint. you wanna go even more tough get DuPont Impron paint, its what they spray big rigs and the like with. you never really see chips on them do you?
the other thing i can think of is that the coats are too thick, I have 5 coats on the fenders of my LeSabre after some arse hit the side and I had to repaint a body panel to the right color from the junk yard. at any rate I have only a couple chips after about 35,000kms since it happened.
I think the easy route though would be using an enamel clear coat. enamel is tough stuff and does come in spray cans, its just harder to work with and will need more sanding. but you can get fantastic results from it. and it shines awesome cuz its a very hard surface.
one more thing if its only chipping down to the primer, its most likely that sanding is the issue. I like a 600 grit surface for parts on the front of the car, just takes an extra coat or 2 to make up for the roughness.
and lastly, they make primer specifically for plastics. easily available at the part store... that is if its just ALL peeling/cheeping off.
good luck man. when I first started painting it was a bit of a nightmare sometimes yes :)
just remember its 97% prep and 3% painting.
1998 Bonneville SE, Silver Mist metallic, factory 16" chrome t-stars
- PLIM, PLOG, Belden blues, TR-55s, 180 stat, gutted and insulated airbox, FE2 rear sway, Moog endlinks and bushings,
new UIM and gaskets, DEXFree, Nokian i3 225/60/16, Blazer projector fogs, dual trans coolers
1991 Buick LeSabre Limited, Medium Garnet Red metallic, Chev Eurosport 3.1 Z28 16" rims
- PLIM, PEMs, no CAT, no resonator, Delco coil swap, Belden blues, TR-55s, 180 stat, rice pipe FWI, FE2 rear sway,
Moog endlinks and bushings, Michelin Pilot 225/55/16's, dual trans coolers
