Fuse 9C - (Battery), Radio, Cluster
Cheetah
Year and Trim: 97 White Ei 197K
97 Black SE/SC 185K
Post by Cheetah »
It's been a white :sad:
The fuse Fuse 9C - (Battery), Radio, Cluster keeps blowing. It just happened today.
I did replace the fuel pump (works great), but the fuse is now not working.
No radio, gauges, the electronic climate control, speedometer, tach, boost gauge are all not working.
Any ideas?? I am prepping the car to sell it :sadeyz:
Thank You :hail:
J Wikoff
Re: Fuse 9C - (Battery), Radio, Cluster
Post by J Wikoff »
Sounds like a short. Could be anywhere in the circuit, after the fuse.
