98 SE rusted out rocker panel
Djkthegame
1987 Bonneville LE
Post by Djkthegame »
Anyone on here ever done it or is it junkyard time. Has anyone ever heard of one of these cars collapsing?
"CERTIFIED BONNIEHOLIC"
B I-1999 Bonneville SE -My First Bonnie- gone forever
B II-2000 Bonneville SSEi (black) 7/3/09 ZZpcm 1.0, Thrasher Cold Air Intake, Magnaflow hi-flow cat, 180 thermostat, Autolite 104's, solid hockey puck front mount, Intense 3.4 MPS. (OCT 2010 COTM Nominee)
B III-1987 Bonneville LE (burgundy) 7/22/10 -- Gone to Heaven
B IV-1991 Bonneville LE (black) 12/6/12 Parts Car -- Gone!
B V-1998 Bonneville SE (green) 9/11/13 -- 270,000+ and going strong! -- gone 287k+
B VI-1989 Bonneville SSE(gray)9/23/15
SSEiMan01
Re: 98 SE rusted out rocker panel
Post by SSEiMan01 »
The rockers on a 92-99 aren't structural. My LeSabre had hardly anything left, and the 96 is getting there. It's mostly subframe mounts/cradles you want to be sure are solid.
James May wrote:Hello.
MattStrike
Year and Trim: '99 Montana
'92 Trofeo
Post by MattStrike »
The outer panel of the rocker by itself is not structural, but the metal behind it is. So take steps to start cleaning and protecting that inner metal, get mudflaps, or something. If you have mouldings that cover it you probably don't need the mudflaps.
Djkthegame
1987 Bonneville LE
Its rusted out right infront of the right rear tire
MattStrike
'92 Trofeo
Yep, cut out the rust if you can, clean the inside as best you can, and seal it up so crap from the tire doesn't get in and make it worse.
Edit: This didn't fall apart driving down the road
http://www.pontiacbonnevilleclub.com/fo ... 34189.html
Djkthegame
1987 Bonneville LE
MattStrike wrote:Yep, cut out the rust if you can, clean the inside as best you can, and seal it up so crap from the tire doesn't get in and make it worse.
I think im gonna have to get the same section cut out in mine.
