2000 SSEi add sub to stock stereo?
Blk2000SSEI
Year and Trim: 1965 Bonneville
2000 SSEI Black
Post by Blk2000SSEI »
I was wondering if its possible to add a sub to a stock stereo system on my 2000 bonneville. I really want to keep the stock stereo in the car if possible.
haro1225
Year and Trim: 2004 GTO
Re: 2000 SSEi add sub to stock stereo?
Post by haro1225 »
You need to get a line out converter, it splices into the rear speaker wiring. Then you would have to find a switched power source to power up the amp.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
Get a line out converter and tap into one of the rear 6X9's for the sound signal. Get an amp of your choice and hook up the RCA inputs to the amp from the LOC, and then hook up the sub to the amp. Run the turn on lead from the amp to the fuse box under the back seat to the IGN 3 fuse. Your amp will turn on when the key is on the ON position but won't work on ACC. However, if you put the key right in between the ACC and ON positions, the car will be in ACC mode but the amp will run. That is how mine is set up and I have no issues.
bobgto65
2004 Bonneville GXP
Post by bobgto65 »
If you are still going to use the Bose amp for the other speakers, then you also tap into the 12v amp turn on wire coming from the radio to the amp to turn on the sub. Just unplug the connector to the Bose amp and use a DMM to test the wires going into the sub until you find the one that is 12V when the radio is turned on and is zero volts when the radio is turned off.
bobgto65
bobgto65 wrote:If you are still going to use the Bose amp for the other speakers, then you also tap into the 12v amp turn on wire coming from the radio to the amp to turn on the sub. Just unplug the connector to the Bose amp and use a DMM to test the wires going into the sub until you find the one that is 12V when the radio is turned on and is zero volts when the radio is turned off.
Ah yes, you could totally do that instead and save yourself trouble. My car didn't have an amp in the stock system.
