transmission lines
transmission lines
On saturday i installed a new radiator in my bonneville. everything went but i notice that i have a little leak on my transmisson line. the leak is not coming from the screw part because i use thread tape but its coming from where the line go in between the bolt. How could i fix this? Any ideas? please help.
Re: transmission lines
And yes the screw is tight.
Take the thread tape off clean the threads and re install them
widtrak77
- Year and Trim: 2000 Buick Park Avenue Ultra
1999 Bonneville SSEi
On the radiator, is the return line always the bottom or is it the other way around?
96 SSEi
- Posts like a Northstar
hi, yes, take it off, clean well, put loctite gasket sealer on it and its good till you mess with it again - dont forget to clean the rad part before loctite also
they should be different fittings for lines
