Shifting while wot
Bonnie01
- Year and Trim: 2001 Pontiac Bonneville SE
Shifting while wot
This might be a stupid question. While the pedal is to the floor, do you guys have the transmission in Drive, or is it better to start in 1 and shift through to D? I have shaved off some seconds shifting through the gears compared to being in drive. Yet im worried that the transmission cant handle it. It has been rebuilt once.
Re: Shifting while wot
It's the same force whether you do it or you let the computer shift it, and the computer reacts a lot faster than you do. The clutches and hard parts are the same as what's in an S/C car, the only real difference is the differential. It can take it.
- RJolly87
The big concern is the engine. In stock form it may short shift a bit, but not much. If you are shaving seconds, i have to question the rpms you are turning. In stock form, there is not much gain at redline, and the valvetrain is usually the weakest point
- RJolly87
Btw, shiftpoints can be adjusted with a tune, if you really want to fiddle with things
- haro1225
- Posts like a Northstar
- Year and Trim: 2004 GTO
I would leave it in D if you are doing pulls. The other gears could be used if you wanted to force a downshift, or maybe for autocross to hold a gear. If you do shift it yourself, be careful and watch the revs. I over revved my last car doing that and killed the engine.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
2003 SSEi
- Posts like an L67
- Year and Trim: 2003 SSEi.
LOTS of Mods
Shifting the trans manually will actually be slower than the computer. Also there are Other things that happen when the trans is put in Manual 1 and 2 vs 3 and Drive.
The only time I have the car in Manual 1 or 2 is to do a burnout in the water box at the track,
I will pull the car down into 3 if im on the highway and want to do a WOT pull
- Jfridge92
- Posts like an L67
- Year and Trim: 1999 Buick Lesabre Custom
Any time I've ever timed my car, I've gotten the quickest results in 3 vs. manual shifting or leaving it in D.
Joseph
1999 Infiniti G20T - Sold
Bonnie01
thanks for the input guys. that clarified some questions I had.
- nos4blood70
- Year and Trim: 2003 SLE
Just leave it in drive.
Bonnie01
That's my conclusion
