block heater
Posted: Sat Sep 21, 2013 8:41 pm
by 95se
Which freeze plug is the best to pull to use a aftermarket block heater?
Re: block heater
Posted: Sat Sep 21, 2013 10:11 pm
by crash93ssei
Why do you want a block heater?
Re: block heater
Posted: Sat Sep 21, 2013 11:22 pm
by yourgrandma
For in car installation I think the front drivers side plug is about the only option.
Re: block heater
Posted: Sun Sep 22, 2013 12:13 am
by 95se
Cold winters here would be nice to get in a warm car in 5 mins over 15-20mins. Cold as in lower than 20 degrees
Re: block heater
Posted: Sun Sep 22, 2013 12:24 am
Yeah, whichever one you have the best access to...
Re: block heater
Posted: Sun Sep 22, 2013 1:03 am
by 95se
ive installed a few but how do you remove the old ones?
Re: block heater
Posted: Sun Sep 22, 2013 1:04 am
Screwdriver through it, pry it out. Drain the coolant out first...
http://www.youtube.com/watch?v=2fhK1sM6LB4
Re: block heater
Posted: Sun Sep 22, 2013 1:05 am
by 95se
sounds easy enough
Re: block heater
Posted: Sun Sep 22, 2013 12:13 pm
by yourgrandma
Just FYI but I tried three different heater plugs and toggle bolts and they all had catastrophic blow outs causing total coolant loss.
Re: block heater
Posted: Sun Sep 22, 2013 1:41 pm
by 95se
Thanks for the info maybe i wont try this, dont need stranded
Re: block heater
Posted: Wed Sep 25, 2013 12:35 pm
by SC-Type
yourgrandma wrote:Just FYI but I tried three different heater plugs and toggle bolts and they all had catastrophic blow outs causing total coolant loss.
as such:
http://www.pontiacbonnevilleclub.com/fo ... 40233.html
But I've never had issues before on other vehicles, and plan to reinstall a new one. Continueing within the thread, I found one of my ports in the front head to be sevearly blocked, and might have created excessive pressure resulting in the blow out.
Re: block heater
Posted: Wed Sep 25, 2013 12:44 pm
Re: block heater
Posted: Wed Sep 25, 2013 2:35 pm
by 95se
Thats a good thread and idea!
