block heater
95se
Year and Trim: 1995 se bonnie
block heater
Post by 95se »
Which freeze plug is the best to pull to use a aftermarket block heater?
1995 se
128,101
custom FWI
rt-95 rims look kinda like crosslaces
6000k hids
f- body muffler dual output
96-99 headlight conversion, clear markers
crash93ssei
Re: block heater
Post by crash93ssei »
Why do you want a block heater?
yourgrandma
Year and Trim: '02 SSEi
Re: block heater
Post by yourgrandma »
For in car installation I think the front drivers side plug is about the only option.
95se
Re: block heater
Post by 95se »
Cold winters here would be nice to get in a warm car in 5 mins over 15-20mins. Cold as in lower than 20 degrees
1995 se
128,101
custom FWI
6000k hids
Re: block heater
Yeah, whichever one you have the best access to...
95se
Re: block heater
Post by 95se »
ive installed a few but how do you remove the old ones?
1995 se
128,101
custom FWI
6000k hids
Re: block heater
Screwdriver through it, pry it out. Drain the coolant out first...
http://www.youtube.com/watch?v=2fhK1sM6LB4
95se
Re: block heater
Post by 95se »
sounds easy enough
1995 se
128,101
custom FWI
6000k hids
yourgrandma
Re: block heater
Just FYI but I tried three different heater plugs and toggle bolts and they all had catastrophic blow outs causing total coolant loss.
95se
Re: block heater
Post by 95se »
Thanks for the info maybe i wont try this, dont need stranded
1995 se
128,101
custom FWI
6000k hids
SC-Type
Year and Trim: 1988 Buick Lesabre T-Type
Re: block heater
Post by SC-Type »
yourgrandma wrote:Just FYI but I tried three different heater plugs and toggle bolts and they all had catastrophic blow outs causing total coolant loss.
as such:
http://www.pontiacbonnevilleclub.com/fo ... 40233.html
But I've never had issues before on other vehicles, and plan to reinstall a new one. Continueing within the thread, I found one of my ports in the front head to be sevearly blocked, and might have created excessive pressure resulting in the blow out.
Re: block heater
95se
Re: block heater
Post by 95se »
00Beast wrote:Might try this instead: http://www.pontiacbonnevilleclub.com/fo ... 16032.html
Thats a good thread and idea!
1995 se
128,101
custom FWI
6000k hids
