mildewy smell when I turn on my air
- ballstatefan05
- Year and Trim: 2005 SE
Hey all ~
I have this odd smell that comes out of the vents when i turn on my air. Its a damp/mildew smell. I just had the condenser replaced a couple weeks ago. Any ideas on whats going on or how to get rid of it?
- nos4blood70
- Year and Trim: 2003 SLE
Re: mildewy smell when I turn on my air
Happened in my car when I turned the air on for the first time in a while, then it all blew out.
- gweg_b
- Posts like a Northstar
- Year and Trim: 95 LeSabre Custom
01 Bonneville SSEi
09 G8 GT - Location: Cambridge, OH
Mine has that smell all the time, the whole car does really. Even after fixing the leaks and drying the hole car out.
Sort of smells like wet dog too. . .
- SSEiMan01
- Year and Trim: .
03 PAU - Location: DeKalb, IL
Have you replaced your cabin air filter ever? Lol
You can also spray some odor neutralizer (Fresh Wave) on the cabin filter if it's clean. That would be where I'd start.
James May wrote:Hello.
- nos4blood70
Or put an air freshener inside the blower motor. XD
- ballstatefan05
Well, I'm not sure I have, where is it? LOLSSEiMan01 wrote:Have you replaced your cabin air filter ever? Lol
I can't say I knew there was one of those..just the air filter on by the engine...
- ballstatefan05
This just started happening after the condenser replacement. Its been really hot here so I use the air quite a bit..nos4blood70 wrote:Happened in my car when I turned the air on for the first time in a while, then it all blew out.
- SSEiMan01
- Year and Trim: .
There is a panel in the cowl area near the windshield, under the hood, two little tabs holding down, under there is the cabin filter. Some previous owner may have left the filter out. But they are readily available at your local parts store.
Could be a plugged A/C drain as well. It's accessed from under the car, on the passenger side of the firewall. It's just a small rubber tube, might not hurt to stick a small screwdriver or something in there to ensure it's not clogged.
- ballstatefan05
ok, so there isn't even a cabin filter in the car (no bracket either)..should I worry about it?
It does really help to have one. 03+ didn't get a bracket, just got a filter tossed in there. Go to your favorite parts store and get a filter with the bracket (might have to order it). It's like $20, and it keeps the dust and pollen out of your car and your lungs.
- ballstatefan05
Will this one fit? I see in the reviews someone installed this one in an 04 Bonneville...00Beast wrote:It does really help to have one. 03+ didn't get a bracket, just got a filter tossed in there. Go to your favorite parts store and get a filter with the bracket (might have to order it). It's like $20, and it keeps the dust and pollen out of your car and your lungs.
http://www.amazon.com/ACDelco-CF140-Fil ... bonneville
Yep, that's it.
- nos4blood70
It made my car get a lot less dusty! The dash stays clean for weeks at a time.
- ballstatefan05
That would make me and my OCD super happy! Mine gets real dusty real quick..missing filter is probably why I'd say..nos4blood70 wrote:It made my car get a lot less dusty! The dash stays clean for weeks at a time.
Also, be sure that you actually disposed of the water in your car. The carpets have a 1.5" - 2" thick polyurethane cushion / sponge underneath that i had to pull up & squeeze out. Doesn't hurt to drive around with the AC & blower at full for a while to make it dry, especially if you are not getting to much sun.
2000 Dark Bronzemist Pontiac Bonneville SE 3800 Series II L36
1998 Bright Arctic White Chevrolet Lumina LS 3100 Generation III L82
- ballstatefan05
I just drove 30 min with AC blasting, when I got home I looked under the car for AC condensation drip..there wasn't any, but then again I'm not a weather girl and I'm not sure of conditions that would make my AC have condensation....
I'm having my oil changed on Wed. I'll have them check the drain hose for clogs anyway...
Should be dripping water out pretty good, no matter how humid it is. The more humid, the more water dripping.
- ballstatefan05
ok guys, so I had my oil changed yesterday and I asked them to check the drain hose for the A/C..they couldn't find it!!
Any tips on helping them locate it. I don't think the guy changing my oil had much experience under his belt..although he did great with the oil change itself..
Thanks,
Jaime
Thanks,
Jaime
- harofreak00
