any one out there willing to help me with some links or right up on how to install radiator for 98 ssei thing just cracked yesterday its temp sealed using a bonding pudy to get me and wife to work going to tackle in the morning with my dad so any help is appreciated ty Rob
parts i have
radiator http://shop.advanceautoparts.com/webapp ... 7CL3*15952
upper/lower rad hoses because both have failed before
new thermostat
hose clamps
transmission fluid http://shop.advanceautoparts.com/webapp ... _8130008-p
coolant http://shop.advanceautoparts.com/webapp ... rm=coolent
rubber plugs for trans lines
radiator installation gide help 98 ssei
incounterman
- LE Member
- Year and Trim: 1991 ssei pontiac bonneville
- haro1225
- Posts like a Northstar
- Year and Trim: 2004 GTO
Re: radiator installation gide help 98 ssei
Its pretty easy. Once you get all the hoses and trans lines unhooked, remove the plastic cover on the core support (above the rad) and it should come right out. At least that's all that was holding mine down.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
I like the core size, but I would have told you to order one for a 95 SSEi.... But the 1 inch core should be better than what's already there by a good bit..
I actually used a caddy radiator on my 95 SE... I think the core is 1-3/8 iirc..
Removal and install is not bad either...
