driver window switches
jnl518ssei
- SE Member
- Year and Trim: 2000 ssei
Have searched the forum and can't find an answer. My 2000 ssei's window switches are lit up after the car is off. Its the first time I've noticed it. Is this normal or not? My gas tank lock doesn't function either. Any help out there?
2003 SSEi
- Posts like an L67
- Year and Trim: 2003 SSEi.
LOTS of Mods
Re: driver window switches
if the drivers door is open after the car is shut off, then the Lock, Seat Memory and the Window switches will be light up
- bobgto65
- Posts like an L36
- Year and Trim: 2002 SSEi
2004 Bonneville GXP - Location: Maryland
This is normal. And the light for the igniton switch stays on. They all turn off when the courtesy lights go off after you lock the car or eventually the will go off even with the door open.
bobgto65
- nos4blood70
- Year and Trim: 2003 SLE
Try to put some WD40 in the little tab that slides out to lock the gas door. It got mine working.
jnl518ssei
- SE Member
Well I walked the dogs last night. Opened and closed all the doors after and the lights went out. Ill lube all the light switches in the doors after work today. Hopefully no more issues afterwords. Thanks peoples.
Don't use WD-40 in the door switches! Just in the Gas door lock!
mrwildroot
- SSEi Member
- Year and Trim: 2000 Bonneville SE
You can purchase a spray for the switches at Radio Shack.
We used to use "Tuner Cleaner/Lubricant" in the old days...Any good Contact Cleaner/Lubricant should be fine for your door switches.
MW
MW
Ken_W
- Posts like an L27
- Year and Trim: 2000 SSEi
Most of those gas door locks are shot. Neither of my two Bonne's had one that worked, and it never affected anything (unless you live in a high-crime area and worry about gas theft?).
Ken
Ken
Even then i dont think you can even get a hose into the fuel tank... i believe there is a screen to keep large junk from going in.. as part of the filler neck.Ken_W wrote:Most of those gas door locks are shot. Neither of my two Bonne's had one that worked, and it never affected anything (unless you live in a high-crime area and worry about gas theft?).
Ken
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
