KR scanning
KelvinVV
Year and Trim: 2002 Pontiac Bonneville SSEi
Member #8782
KR scanning
Post by KelvinVV »
Where can I purchase or rent a KR scanner? I want to see where I'm at beforehand so I know what I can and cant do. I would rather have some sort of OBDII scanner if that would work, because if I bought a gauge i would have to sacrifice one of my vents, and I like my flowing air.
Also, what levels of KR are 'safe'? Like how much KR would make it impossible to run a 3.5 pulley with supporting mods?
Kelvin VanderVeen
PERFORMANCE MODS
180 DEGREE THERMOSTAT, AUTOLITE 104'S, ZZP VOLTAGE BOOSTER
APPEARANCE MODS
LED INTERIOR LIGHTS, TAN INTERIOR TRIM, CLEARED CORNERS
:bpylons:
Re: KR scanning
0 KR is always the best possible result, but 1* or so is relatively *safe*. And it depends on the day and the other mods, and most importantly the tune. If you have any KR, a 3.5 is going to make it worse...
KelvinVV
Member #8782
Re: KR scanning
Post by KelvinVV »
I know, so i want to try to get it as close to 0 as possible. I'm not sure i want to go all the way down to a 3.4 so I think a 3.5 would be alright. I'm planning on doing every support mod I can before I even buy the pulley, though, to prevent as much KR as possible.
Kelvin VanderVeen
PERFORMANCE MODS
APPEARANCE MODS
:bpylons:
Re: KR scanning
Definitely not a bad plan. I ran a 3.6 and had minimal KR with that, with quite a few supporting mods. You're rarely ever going to hit 0 KR at WOT, but minimizing it during the powerband is what's important. You'll see some KR around the shifts, that's to protect the transmission from getting shocked too hard.
Re: KR scanning
And the Aeroforce really is the right tool for the job. Yes it means you have one less vent, but the other 3 pick up the slack, each pair shares a common plenum behind them. You don't lose flow, and it makes sense on so many more levels. It was by far the best mod I did to my 03, bar none.
gweg_b
01 Bonneville SSEi
09 G8 GT
Re: KR scanning
Post by gweg_b »
For a scanner I know there is an app for Android (Torque I believe it's called), and along with a Bluetooth OBDII scanner, you can probably scan for KR. I'm not 100% sure as I went the AeroForce route (Ed's right, you don't lose much, unless you put one in all your vents).
Also, depending on how you car's previous owner treated it (like running it hard on 87 instead of 91), you may have a difficult time getting rid of knock, even with the supporting mods. But, if it was treated well, you shouldn't have too many problems. I know this because mine was abused by its previous owner, and running a 3.6 pulley in the winter netted me around 8*+ of KR, and that wasn't even at WOT.
KelvinVV
Member #8782
Re: KR scanning
Post by KelvinVV »
The thing that really bothers me is the price on this thing. I would gladly buy one if it were much cheaper. Is it really worth the $250 price tag? I
mean there has to be some other OBDII scanner that costs much less, doesn't there?
I wish someone would just invent a scanner that just read KR and was affordable! Ha I'm dreaming, though, unless I'd go out and do it myself.
Kelvin VanderVeen
PERFORMANCE MODS
APPEARANCE MODS
:bpylons:
Jfridge92
Re: KR scanning
Post by Jfridge92 »
Torque Pro for android is $5, and the bluetooth adapter for the OBDII port is 20ish on amazon. I have that and it works like a charm, and will read KR and a lot more. It's worth the investment, and is much better than the aeroforce if you're on a budget. The aeroforce is a better gauge overall, but for the price you can't beat Torque.
Joseph
1999 Infiniti G20T - Sold
Re: KR scanning
I never got Torque to read KR. Not sure what I am or am not doing right...
Ohhhh, got it. You have to go to: Settings > Manage extra PIDs/Sensors > hit Menu > Add Predefined Set > Pontiac/GM/Opel/Vauxhall. Then it adds KR and a bunch of other stuff. Perfect.
KelvinVV
Member #8782
Re: KR scanning
Post by KelvinVV »
Do you need an android product to do this?
Kelvin VanderVeen
PERFORMANCE MODS
APPEARANCE MODS
:bpylons:
Re: KR scanning
IIRC the iPhone 5 or the newest iOS doesn't work with the BT adapters, so basically yes, lol.
KelvinVV
Member #8782
Re: KR scanning
Post by KelvinVV »
Dang. Now that I'm looking at the Aeroforce website and looking at all it does, I'm kind of looking into possibly buying one, but more than likely it would have to be used, since I'm so cheap. :bpylons: :wiggle:
What I would probably keep it on is Horsepower and KR readings all the time.
If I do end up buying it, how do plug it in? does it just go right into the OBDII port and its good to go? Or do I have to mess with wires and end up ruining the $250 piece of plastic?
Kelvin VanderVeen
PERFORMANCE MODS
APPEARANCE MODS
:bpylons:
gweg_b
01 Bonneville SSEi
09 G8 GT
Re: KR scanning
Post by gweg_b »
Plugs right into the OBDII port. Simple and easy.
crash93ssei
Re: KR scanning
Post by crash93ssei »
I have a ScanGauge II which does everything the aeroforce does but it is rectangular in shape so doesn't blend in so easily, but it is much easier to read as the display is larger. It also scans and clears check engine light codes. These gauges are great for troubleshooting and they really tell you a lot about what is going on with your car, yes they are worth $250.
Re: KR scanning
I loved my Aeroforce, probably going to get another one for my next car (Needs a different aeroforce due to the CAN-bus protocols). If you'd have been quicker, I just sold mine for $150. ;)
For DD duty, I had mine showing Coolant temp (Don't want to get on it till 160*, when it goes into closed loop and knock is processed) and Trans temp, just to monitor that. Then when I wanted to go fast, it was usually LTFT (Long Term Fuel Trim) and KR.
maroon111993
Year and Trim: 1997 Grand Prix GTP
Re: KR scanning
Post by maroon111993 »
Jfridge92 wrote:Torque Pro for android is $5, and the bluetooth adapter for the OBDII port is 20ish on amazon. I have that and it works like a charm, and will read KR and a lot more. It's worth the investment, and is much better than the aeroforce if you're on a budget. The aeroforce is a better gauge overall, but for the price you can't beat Torque.
Works just fine for me as well :) Best purchase I've ever made. And many apps work with the adapter as well. Shows absolutely everything you need to know down to BHP or fuel trim levels. :)
1997 Grand Prix GTP "Black Ice, 'cuz it's slick" - 17" Motegi Racing Rims, Hankook Optimo Performance Tires, 'Big 3' Wiring Upgrade, Weapon R Secret Weapon Intake w/ Ram Air, Larger SuperCharger lines, AutoLite 104's, U-Bend Delete, Resonator Delete, Cat Delete, Turbo Flowmaster Mufflers. 342bhp, 327 lb-ft torque, 9.091 boost psi @ 6,012 rpm.
Re: KR scanning
Look around on the more frequent 3800 forums like GPF and you can usually find used Aeroforces for sale for like 175 bucks.
drift7one
Year and Trim: 2002 Pontiac Bonneville SE
Re: KR scanning
Post by drift7one »
just got the Torque app, added the KR option and it works great. always at 0.0, except some WOT highway runs got a couple degrees (false KR hopefully, but it did get up to 7.4 once.)
drift7one
Rich- Member #6668
Golden Hurricane
| Cleared Headlights | 20% Tinted Windows | AVS VentVisors | Viper 2-Way Alarm System | Garmin GPS Navigation |
| DDM Tuning 8000k 35w HID Headlights | Nokya Hyper Yellow 2500K Fog Lights | Black PlastiDip Accents & Badges |
Re: KR scanning
drift7one wrote:just got the Torque app, added the KR option and it works great. always at 0.0, except some WOT highway runs got a couple degrees (false KR hopefully, but it did get up to 7.4 once.)
HOWW. I only get zero on frigid nights with 93 octane. Going anywhere near WOT under normal situations has gotten me as high as 9 degrees on 87 and 5-6 on 93. :ballkick:
parkaveman83
Year and Trim: 96 park ave ultra
Re: KR scanning
Post by parkaveman83 »
Mine does the same thing. 0 wide open. But will hit 3-5 on heavy part throttle.
