I've my 2002 Pontiac bonneville car brought before a month and the previous owner had lost his keyfob and had only a master key.
Now that i have brought a OEM Key fob transmitter from Ebay and looking for programming instructions, few sites say i need a programmer device OR need to contact a dealer. And few say to follow methods like shorting connector pins below the driver dash area and pairing it.
Reference : http://blog.keylessentryremotefob.com/2 ... emote.html (Instructions for 1996 model)
And another site, said this
program the remote to your 2002 Pontiac Bonneville without any help from the dealer. This includes the GT model.
Programming Instructions: Note: This is the same for many GM vehicles.
Look beneath the driver’s side dash. You’ll see a programming connector with two rows of slots. Insert your jumper wire into the top right slot and the bottom left slot. This jumps the pins and activates the programming mode. You’ll hear the door locks cycle.
Push the “Lock” or “Unlock” button three times on the remote you wish to program rapidly. This programs the remote to the vehicle. Repeat for additional remotes.
I tried the second method and ON OFF method 3 times as in other models, nothing worked. Unable to get the car to programming mode..
Planning to try the first method today evening, meanwhile if anyone knows the correct procedure. Please HELP. !!
