Second o2 sensor location?
BRUTE FORCE
Post by BRUTE FORCE »
Does anyone have a pic of the loctation for the second o2 sensor? I installed a zzp downpipe and I can't seem to find the sensor.
Re: Second o2 sensor location?
Who installed the Downpipe?
BRUTE FORCE
I had the local speed shop install it. When I left the shop the ses light came on. I figured it had to be the 02 sensor after the cat. The downpipe was installed directly to the resonator. I figured the mechanic removed the sensor before deleting the cat. I just need to know where to look so I can order the 02 emulator from ZZP.
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
you can see the sensor plugged in to my downpipe... it normally is routed under the heat shield. so my guess is its stuffed in there:
Shane "RedZMonte"
2004 Z16 Z06: Virgin
BRUTE FORCE
Thanks redzmonte :)
