Digital gas meter
Redrum84
Year and Trim: 04 Bonneville GXP
Digital gas meter
Post by Redrum84 »
What's up everyone?! I had a quick question. I just replaced the fuel sensor on my 04 bonneville gxp, and now the digital gas reading is always bouncing around. Does anyone have any ideas on what it might be???
Re: Digital gas meter
Does the gauge do the correct sweep on startup? 02+ are known for faulty stepper motors in the cluster. I repair them for $75.
Redrum84
Post by Redrum84 »
Yea it does. The only one that doesn't do it is my battery gauge. That stays all the way to the right
I'd still guess its a batch of faulty stepper motors. I replace all 6 motors and all 8 backlight bulbs.
Redrum84
Post by Redrum84 »
I'm in Chicago though
Ship it.
Tazman3212
Year and Trim: 2000 Pontiac Bonneville
Post by Tazman3212 »
My car does the same thing.. what you should do, is drop the gas tank, and check the sending unit. GM did a butthole job when makin the sending unit, thats what i need to do to mine. it'll be accurat until down to like 3/8's tank then it'll start going back uo and it gets hairy.. especially when it'll go from 1/4 tank back up to full.. so check the sending unit, and if thats the case then might aswell replace the fuel pump while under there. dont know the cost, but i bet that is your issue if its anything like mine
drift7one
Year and Trim: 2002 Pontiac Bonneville SE
Post by drift7one »
drop the tank? there's an access panel in the trunk, you can get to everything in the '00+. sender is under $30
drift7one
Rich- Member #6668
Golden Hurricane
| Cleared Headlights | 20% Tinted Windows | AVS VentVisors | Viper 2-Way Alarm System | Garmin GPS Navigation |
| DDM Tuning 8000k 35w HID Headlights | Nokya Hyper Yellow 2500K Fog Lights | Black PlastiDip Accents & Badges |
