Just noticed on my way to work the headlights and dash light were just randomly flickering. Also did it ( even more noticeable ) while shifting it from drive to park, actually whenever you moved the shifter at all. The battery voltage when running kinda bounces from 14-15 volts and 13-14 when at a stop.
I'm just about to install an aftermarket radio and amplifier so the last thing I want is electrical issues. Has anyone heard of this issue before?? Thanks
Car is a 2006 Grand Prix gt. s/c series 3
Help!! Dashlights, headlights flickering constantly.
- comatoast
- Posts like an LN3
- Year and Trim: 2000 SSEi
Current mods - FWI, Intense 1.0 PCM, 3.4"- 3.5", Intense MPS, AL 104s, 180 Stat , Intense/TG shiftkit, Aeroforce Interceptor scan gauge
Upcoming mods- 1.9 rockers, 105#springs, Headers, 103s, 3.3, tune..
steelmanwy
- Year and Trim: '03 SE, Galaxy Silver
Re: Help!! Dashlights, headlights flickering constantly.
I have the same symptoms (bouncing voltmeter and dimming/flickering lights) but have not added anything aftermarket. Shifting and applying brakes seem to make it the most noticeable. I haven't done any troubleshooting yet, so hopefully someone here has some knowledge.
Kurt
'03 Bonneville SE
'07 Yukon XL
'00 K2500 Crew
Kurt
'03 Bonneville SE
'07 Yukon XL
'00 K2500 Crew
- comatoast
- Posts like an LN3
heres my first issue ( below ) and other than the obvious, starter, alt, battery, ground(s), headlight switch, Some ppl have said the PCM might be an issue.. But that is obviously a last resort
- harofreak00
I know you said its a GP in the post, but please update your sig to match.
steelmanwy
My battery terminals are squeaky clean, but it ended up that the side-post bolts were loose...when I took the battery out to have it checked at the auto part store, I could see some pitting from arcing and knew what was up right away.
Kurt
'03 Bonneville SE
'07 Yukon XL
'00 K2500 Crew
Kurt
'03 Bonneville SE
'07 Yukon XL
'00 K2500 Crew
