duplicolor touch up
duplicolor touch up
Post by gonzo4191 »
i ordered some duplicolor touch up paint for my car (code 812k). i cleaned the surface, then applied the primer. i have now put on two coats, but it isn't matching, will the clearcoat on top change it to match??? :sad: !!! :helpsmilie:
bonnevillain
Re: duplicolor touch up
Post by bonnevillain »
nope. your paint has faded over the years. i actually found a random color that was much closer than the "correct" duplicolor match because mine was so far off.
Does it look closer when the paint is still a liquid, or when its dry?
I doubt your 04 has faded paint... I'm guessing the touchup just isn't right.
I ordered my touchup for my 00 from http://www.automotivetouchup.com/ and it was PERFECT, although a clear coat would have gave it the correct shine.
Post by gonzo4191 »
closer while wet.
the names still match between the two. "WA812K Med Spiral Gray Met"
i might try your site, i need to get this fixed :)
If its closer when wet, a good clearcoat would help you out a lot.
Post by gonzo4191 »
recommendation andrew??
Get the same brand touchup clear as the paint you bought.
grandprix104
Year and Trim: 2001 SE L36
Post by grandprix104 »
FYI - Duplicolor doesn't always match. When I went to the body shop they first told me to use the Duplicolor but when I told them it didn't match they looked up my VIN# and found that that for my car they used a variant of my paint code that was a little more of a cream color. They were able to then mix a perfect match and put it in a rattle can. You could do the same and just spray it on a paper plate and use a small brush to touch up scratches.
2001 Pontiac Bonneville SE 3.8n/a 110k, PLIM, APN UIM, 180 T-stat, Clarion DXZ385USB, Memphis 6.5s/6x9s/12" PR sub, Kicker ZX700.5 Amp.
1999 Jeep Grand Cherokee Limited 4.7 V8 120k, WAAG Brush Guard, 2in Lift, SkyJacker Shocks, HD front driveshaft, Infinity Tweeters, 12" Memphis sub, Rockford Fosgate Punch amp
1994 Pontiac Grand Prix 3100 180k SOLD :(
bonnevillain
seems duplicolor is hit and miss depending on your color. some have great results, some bad.
RookieSSei
Year and Trim: 2002 SSEI
ALL STOCK (FOR noW)
Post by RookieSSei »
mine was bad i used on my t-bird and it didn't match at all , it was way off almost like night and day :bhuh:
bonnevillain
i had the same experience, but some swear by it.
chopper442
Year and Trim: 1997 SSE
Post by chopper442 »
I used it for my hood vents...was a match...but my car is white, just got lucky I guess... :roll:
1997 SSE - Bright White -Gutted box, Overlays, GTA vents, cleared corners, calipers..so far.
mas
Year and Trim: 1998 Boneville SE
1991 LeSabre Limited
Post by mas »
This has not been mentioned yet:
>>> Blending Solvent <<<
Blending solvent is a mixture of solvent and clear which will "melt" into the overspray. It is used AFTER you are done clear coat. When I first started painting cars a decade ago I had no idea such a thing existed. I would always make the patch area too big and try and sand/feather it in. This method does work... to decent results but no where near what an auto body shop will give you. With blending solvent it will be like it never happened. Plus you have half the sanding to do because like I mentioned it melts into the over spray.
Also, if your car is metallic coat you MUST wet sand. MUST. The main idea of wet sanding is to color match any ways. God bless 3m Imperial wet/dry sand paper. Its the cats ass. Serious its the best sand paper I have ever used. Bust out the garden hose and keep er good and wet while sanding. There is no way in hell you will color match w/out wet sanding even if the paint on the car, and in the can are EXACT. Its not so much the COLOR is different, its that the metallic flakes are not... for lack of better words lined up the same as all the other ones on the car. So when the sun glints off the flakes on an poorly sanded panel it sticks out like a sore thumb. Also, do NOT sand in circles for the top coat. It will look like a Zebra if you sand in circles. Sand only in one direction, nine out of ten times with the LENGTH of the pannel. Metallics have a mild learning curve vs solids.
This wont be your issue because your panels are bolted on the car already but its a neat tidbit. Gravity also plays a small role in color matching with metallics. Paint should be sprayed onto panels the same way they will be orientated on the car, its all how the metallic particles "settle". So for example, dont lay a fender flat to paint it. Paint it in the up right position as it would be bolted to the car, this will make it match the OTHER cars panels better. Were talking like fractions of a shade here though... more of a thing you worry about when doing say a body off restoration of a fine collectors car. Just a neat tidbit. I have painted panels before, from the SAME batch of paint on the SAME day maybe an hour later and once done, its like... wtf its a shade off! *OOOPS* had the panel orientated wrong when sprayed.
However, it is also true that not all so called body matched paints match. I have as well picked up a couple spray balms before that were so far off its not funny. And these were not faded cars, maybe 2-3 yrs old. Honestly though... thats happened like 3-5 times in 10 years. Technique Technique Technique!
As mentioned before by previous posters, once its clear coated it will get a bit darker in color. What ya can do is let your patch dry and then flood it with a garden hose. Aka "temporary garden hose clear coat" hehe. Thatll let ya know what it will look like clear coated.
P.S. Spraying quickly at a shorter distance is better than spraying slow at a further distance. Less overspray. I know I know the can says hold it a foot away... ignore that unless you like overspray. Practice on something first though of course to fine tune speed/distance. I like about 6" away. But thats just me, everyone is different. Its what gets the best results for that person right.
Oh yea P.P.S get some turtle wax rubbing compound. Go nuts with that stuff on the area to fix, it will remove old broken down worn out paint that will cause your patch to not adhere very well and chip/peel/flake easy. I suppose you could just hit the area with some sand paper... but why when you can just use compound. Why take off more paint than is really required, I myself would not.
Uhm thats bout all I can think of right now with a few beers in me already :beerchug:
Have good painting! Good luck! Once you master painting its an awesome feeling. :)
1998 Bonneville SE, Silver Mist metallic, factory 16" chrome t-stars
- PLIM, PLOG, Belden blues, TR-55s, 180 stat, gutted and insulated airbox, FE2 rear sway, Moog endlinks and bushings,
new UIM and gaskets, DEXFree, Nokian i3 225/60/16, Blazer projector fogs, dual trans coolers
1991 Buick LeSabre Limited, Medium Garnet Red metallic, Chev Eurosport 3.1 Z28 16" rims
- PLIM, PEMs, no CAT, no resonator, Delco coil swap, Belden blues, TR-55s, 180 stat, rice pipe FWI, FE2 rear sway,
Moog endlinks and bushings, Michelin Pilot 225/55/16's, dual trans coolers
