AC/ Heat not blowing at all!!!!
- EMTprincess33
- LE Member
- Year and Trim: 2003 Bonneville SE
Hi, so at first the AC wasn't cold in the drivers side so I went to my local store and got a recharge kit, now its snows in my car... lol, then the blower would randomly stop blowing, I figured out that I would have to hit a pot hole on the passenger side of my car to get the blower to start blowing again. After a few weeks that stopped working. My blower would go on and off as it pleases. Even if I have it on Max AC blower wouldn't blow. Then I found a new trick, slamming the passenger side door would make the blower go back on. but once again after a few weeks that trick stopped working. Now i cant get the blower to go on at all. Any Ideas????? Please help!!!
Re: AC/ Heat not blowing at all!!!!
Time for a new Blower motor.
- Archon
- EMTprincess33
- LE Member
Thank you, is it expensive?
- dpnewfie
- Posts like an LN3
- Year and Trim: 2005 GXP
Rockauto.com has them for about $50 for the Delphi model.
2005 Bonneville GXP, 200k and SOLD!J Wikoff wrote:It has been an honor and privilage to have been serviced by you.
A shop will probably bill an hour's labor for it, so if you take it in, it'll probably be around $150 total. I do agree with getting a new Delphi from Rock Auto, the other "aftermarket" brands don't seem to last as long. This way you know you're getting the best part, and not paying an outrageous shop mark-up on a crappy part.
shipmanlights
- SE Member
- Year and Trim: 2000 SLE
2005 SLE
you may be able to give it a kick on the passenger side cover behind the glove box to get it going temporary till you have time to replace it.
2000 SLE
2005 SLE
1980 Z28
1968 JAVELIN
1968 CUTLASS S
2005 SLE
1980 Z28
1968 JAVELIN
1968 CUTLASS S
jaywhitt01
- LE Member
- Year and Trim: 2005 Bonneville SE
can anyone tell me what I need to take out and replace? I have taken the glove box out and can't get any pics or diagrams online to tell me which part I need to replace.
- J Wikoff
- Year and Trim: 1992 SSE
^^Bump for post above that we were slow to approve.
- Archon
You'll have to remove the lower dash panel.
