Hey all! One of the rods in my trunk snapped and need to figure out what the name is. I believe torsion rod or tension rod?? Anyways its the one that forces the trunk open because when i press the trunk button it just sits closed and i have to manually open it.. I know there is 2 bars that run across the back just need the names so i can get the right part. Also ive read that this can be a difficult fix. Is this true? If i have failed to give enough info, let me know and ill do my best to explain.
Thanks
Mike
Anyone know what this trunk piece is called??
PronksBonne
- Year and Trim: 2004 Bonneville SLE
- GMC Guy
- Posts like an LG3
- Year and Trim: 1999 Bonneville SSEi
Re: Anyone know what this trunk piece is called??
I think its the same piece as in this thread.... Haro will know for sure.
viewtopic.php?f=26&t=30198
Tinted 13% Front 3% Rear, MSD Coils and Wires, K&N drop in air and oil filter...more to come as things wear/break!!
Tint it so dark, you won't even know your name
