Here are some pics:
As soon as I got it home, I pulled off the door and went straight to work.
Installed the new door and also pounded out the dents on the fender as much as I could.
Then I pulled off the front fender.
and installed a good one.
Threw in some headlights and a side view mirror
I was pretty pumped to get the body work basically done on the same day I purchased it. Everything I put on the car so far was just parts from my inventory. It still needs quite a few things. It will need a new hood, a shift kit to help with the P1811, it needs a fuel level sender, an oil pressure sender, the rear shocks are SHOT, needs some new tires on the rear and a good cleaning.
