Power Braking
- OnlyAnSE
- Year and Trim: 2001 Bonneville SE
Power Braking
When i try and power brake to get a little extra jump and shoot a gap in traffic from a stoplight i put my ebrake on and then take it off but hold it down with my foot so the rear brakes are locked but my front tires are still free to spin. when the e brake is all the way in the rear tires seem to still roll a bit is this a bad line or what?
Morgan
04 gxp bone stock internals. Touchscreen dash with heavily upgraded sounds system.
- harofreak00
Re: Power Braking
First of all, you shouldn't need to use your parking brake to power brake, just the regular one will work just fine.
The e-brake is adjustable. The adjustment is under the car, near the driver seat. Tighten up the cable and it should perform better.
- OnlyAnSE
Re: Power Braking
I didn't mean power braking haha I just couldn't think of a word to use, probably could have just said "E Brake" but thanks!
Morgan
- Adamus Prime
- Year and Trim: 2000 Bonneville SE/SC
Re: Power Braking
TOKYO DORIFTO!!!!OnlyAnSE wrote:When i try and power brake to get a little extra jump and shoot a gap in traffic from a stoplight i put my ebrake on and then take it off but hold it down with my foot so the rear brakes are locked but my front tires are still free to spin. when the e brake is all the way in the rear tires seem to still roll a bit is this a bad line or what?
2000 Bonneville (S)SE(i) - L26/L32 "top swap" - VS cam - ported M90 - ZZP 3.4" pulley - ZZP PCM tune - INTENSE FWI - Port Matched intake/exhaust - ZZP Power Log Manifolds - ZZP "Stage 2" Trans - 2 1/2" full exhaust - SLP Muffler - Hubcaps
Re: Power Braking
Easy there Bruce LeRoy!Adamus Prime wrote:TOKYO DORIFTO!!!!
Ohh and i would also use your regular brake... the rear brake is made to keep the car from rolling not to over power the engine, the rear will drag and can make a nasty flat spot (trust me i did a mean burn out, drug the rear and smoked the rear tires)
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
